Introdução
If your camera fails or will not turn on, use this guide to replace your camera.
O que você precisa
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
Quase terminado!
Conclusão
