Ir para o conteúdo principal
LG Intuition Camera Replacement
O que você precisa
  1. LG Intuition Camera Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Camera Replacement: passo 2, imagem 1 %32
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Camera Replacement: passo 3, imagem 1 %32
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Camera Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Camera Replacement: passo 5, imagem 1 %32
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Camera Replacement: passo 6, imagem 1 %32 LG Intuition Camera Replacement: passo 6, imagem 2 %32
    • Gently raise the battery from its compartment.
  7. LG Intuition Camera Replacement, Plastic Motherboard Shield: passo 7, imagem 1 %32
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Camera Replacement: passo 8, imagem 1 %32
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Camera Replacement, Camera: passo 9, imagem 1 %32
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
  10. LG Intuition Camera Replacement: passo 10, imagem 1 %32
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
Conclusão
Thomas Morrissey
Membro desde: 10/25/18
616 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 103
