Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Hold the phone camera-side up and locate the rear cover.
Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
Place the plastic opening tool in the small slot below and to the left of the battery.
Pry the battery upward to remove it.
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
Gently move the tool around the perimeter of the screen to separate it from the body.
Flip the device over so the battery compartment faces up.
Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
Repeat this for the white tab on the opposite side of the phone.
Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
Lift the motherboard and slide it towards you by hand to free it from the phone.
