Ir para o conteúdo principal
LG Incite Camera Replacement
O que você precisa
  1. LG Incite Camera Replacement, Battery: passo 1, imagem 1 %32
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Camera Replacement: passo 2, imagem 1 %32
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Camera Replacement: passo 3, imagem 1 %32
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Camera Replacement, Back Panel: passo 4, imagem 1 %32
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Camera Replacement: passo 5, imagem 1 %32
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Camera Replacement: passo 6, imagem 1 %32
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Camera Replacement, Camera: passo 7, imagem 1 %32 LG Incite Camera Replacement, Camera: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the camera near the upper-left corner and use the metal tweezers to carefully detach the black tab.
  8. LG Incite Camera Replacement: passo 8, imagem 1 %32 LG Incite Camera Replacement: passo 8, imagem 2 %32 LG Incite Camera Replacement: passo 8, imagem 3 %32
    • Carefully slide the metal tweezers underneath the camera in order to lift it out.
    • Do not puncture the gold lining surrounding the camera.
    • The camera is glued in place, so there may be a slight resistance.
Conclusão
Uma outra pessoa concluiu este guia.
Kimberly Kha
Membro desde: 04/16/13
163 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-18, Maness Spring 2013 Membro de Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 578
