Ir para o conteúdo principal
LG GW910 Camera Replacement
O que você precisa
  1. LG GW910 Camera Replacement, Motherboard: passo 1, imagem 1 %32 LG GW910 Camera Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Camera Replacement: passo 2, imagem 1 %32 LG GW910 Camera Replacement: passo 2, imagem 2 %32
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Camera Replacement: passo 3, imagem 1 %32
    • Remove six 3mm PH000 screws.
  4. LG GW910 Camera Replacement: passo 4, imagem 1 %32 LG GW910 Camera Replacement: passo 4, imagem 2 %32 LG GW910 Camera Replacement: passo 4, imagem 3 %32
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Camera Replacement: passo 5, imagem 1 %32
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Camera Replacement: passo 6, imagem 1 %32
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Camera Replacement: passo 7, imagem 1 %32 LG GW910 Camera Replacement: passo 7, imagem 2 %32 LG GW910 Camera Replacement: passo 7, imagem 3 %32
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Camera Replacement, Camera: passo 8, imagem 1 %32 LG GW910 Camera Replacement, Camera: passo 8, imagem 2 %32
    • Disconnect the connector using the metal spudger.
    • Peel back the tape on the side.
    • Replacement tape might be needed.
  9. LG GW910 Camera Replacement: passo 9, imagem 1 %32 LG GW910 Camera Replacement: passo 9, imagem 2 %32 LG GW910 Camera Replacement: passo 9, imagem 3 %32
    • Pry open the two plastic hooks using the metal spudger tool.
    • Crack open the black plastic cover using the metal spudger tool. The cover should be easily turned over.
    • The connector might get stuck in the opening while turning over the cover. Twist the connector if needed.
  10. LG GW910 Camera Replacement: passo 10, imagem 1 %32 LG GW910 Camera Replacement: passo 10, imagem 2 %32
    • Remove the camera unit by prying on it.
    • Adhesive will be needed for reassembly.
Conclusão
Jonas Ke
Membro desde: 11/06/18
492 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G6, Hovde Fall 2018 Membro de IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 90
Ao todo: 448
