Ir para o conteúdo principal
LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: passo 1, imagem 1 %32 LG GS170 Battery Replacement, Back Cover: passo 1, imagem 2 %32 LG GS170 Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: passo 2, imagem 1 %32 LG GS170 Battery Replacement, Battery: passo 2, imagem 2 %32 LG GS170 Battery Replacement, Battery: passo 2, imagem 3 %32
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: passo 3, imagem 1 %32
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
Conclusão
Uma outra pessoa concluiu este guia.
Minna
Membro desde: 10/08/14
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-25, Donnelly Fall 2014 Membro de USF Tampa, Team 1-25, Donnelly Fall 2014
USFT-DONNELLY-F14S1G25
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 452
