Ir para o conteúdo principal
LG G6 SIM Card Reader Replacement
O que você precisa
    • Insert wisdom here.
Conclusão
MovilOne
Membro desde: 06/17/14
2.480 Reputação
Autoria de 14 guias
3 comentários
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Responder
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Responder
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 4,302
