Ir para o conteúdo principal
LG G6 Charge Port Replacement
O que você precisa
  1. LG G6 Charge Port Replacement, iOpener Heating: passo 1, imagem 1 %32 LG G6 Charge Port Replacement, iOpener Heating: passo 1, imagem 2 %32
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. LG G6 Charge Port Replacement: passo 2, imagem 1 %32
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. LG G6 Charge Port Replacement: passo 3, imagem 1 %32
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. LG G6 Charge Port Replacement, Alternate iOpener heating method: passo 4, imagem 1 %32 LG G6 Charge Port Replacement, Alternate iOpener heating method: passo 4, imagem 2 %32
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. LG G6 Charge Port Replacement, Fingerprint Sensor: passo 5, imagem 1 %32
    • Apply a heated iOpener to a long edge of the phone for about 2 minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  6. LG G6 Charge Port Replacement: passo 6, imagem 1 %32 LG G6 Charge Port Replacement: passo 6, imagem 2 %32
    • In the following steps you will be cutting through the adhesive on the rear glass panel.
    • Take note of the following areas:
    • In addition to cutting around the edge, there is extra adhesive here that should be cut.
    • Avoid sticking the spudger blade in too far here, to avoid damaging the rear button ribbon cable and chip.
  7. LG G6 Charge Port Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
    • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
    • Lift on the suction cup, and insert a halberd spudger or opening pick under the rear glass.
  8. LG G6 Charge Port Replacement: passo 8, imagem 1 %32
    • Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  9. LG G6 Charge Port Replacement: passo 9, imagem 1 %32 LG G6 Charge Port Replacement: passo 9, imagem 2 %32
    • Slide the blade of a Halberd spudger along the side of the phone, separating the adhesive.
  10. LG G6 Charge Port Replacement: passo 10, imagem 1 %32 LG G6 Charge Port Replacement: passo 10, imagem 2 %32 LG G6 Charge Port Replacement: passo 10, imagem 3 %32
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
  11. LG G6 Charge Port Replacement: passo 11, imagem 1 %32 LG G6 Charge Port Replacement: passo 11, imagem 2 %32
    • Use the opening picks to slice through any remaining adhesive and open the phone.
    • Remove the glass from the phone.
    • During reassembly, apply new adhesive or high-bond tape if your replacement rear glass does not come with any.
  12. LG G6 Charge Port Replacement: passo 12, imagem 1 %32 LG G6 Charge Port Replacement: passo 12, imagem 2 %32 LG G6 Charge Port Replacement: passo 12, imagem 3 %32
    • Slide the blade of a halberd spudger into the opening on the edge of the rear button bracket.
    • Careful not to push directly against the rear button ribbon cable, to avoid damaging it.
    • Do not push the spudger in too far, to avoid damaging the rear button.
    • Continue sliding the spudger blade around the bracket to cut all the adhesive holding the bracket to the rear case.
    • Remove the bracket.
  13. LG G6 Charge Port Replacement: passo 13, imagem 1 %32 LG G6 Charge Port Replacement: passo 13, imagem 2 %32 LG G6 Charge Port Replacement: passo 13, imagem 3 %32
    • Slide an opening pick between the rear button membrane and the rear case.
    • Slide the pick around the edge of the membrane to separate it from the rear case.
    • This might take some force, as the adhesive holding the membrane to the case is tenacious. Pry slowly, to avoid puncturing or stretching the membrane.
  14. LG G6 Charge Port Replacement: passo 14, imagem 1 %32
    • Use the blade of a halberd spudger to pry the rear button chip off of the rear case.
  15. LG G6 Charge Port Replacement: passo 15, imagem 1 %32 LG G6 Charge Port Replacement: passo 15, imagem 2 %32 LG G6 Charge Port Replacement: passo 15, imagem 3 %32
    • Use an opening pick to pry the contact pad off of the rear case.
    • Remove the rear button assembly.
  16. LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: passo 16, imagem 1 %32 LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: passo 16, imagem 2 %32 LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: passo 16, imagem 3 %32
    • Separate the rear glass from the phone,
    • Remove eleven Philips #00 screws.
  17. LG G6 Charge Port Replacement, Remove Charging Coil: passo 17, imagem 1 %32 LG G6 Charge Port Replacement, Remove Charging Coil: passo 17, imagem 2 %32
    • Use a spudger to remove the charging coil from the top left corner,
  18. LG G6 Charge Port Replacement, Remove Loudspeaker Assembly: passo 18, imagem 1 %32
    • Remove loudspeaker assembly.
  19. LG G6 Charge Port Replacement, Battery: passo 19, imagem 1 %32
    • Use the flat end of a spudger to disconnect the battery connector.
  20. LG G6 Charge Port Replacement, Motherboard: passo 20, imagem 1 %32
    • Use the flat end of a spudger to disconnect the LCD/Digitizer flex cable.
    • Use the flat end of a spudger to disconnect the charge port flex cable.
  21. LG G6 Charge Port Replacement: passo 21, imagem 1 %32
    • Use the flat end of a spudger to disconnect the front camera.
  22. LG G6 Charge Port Replacement, SIM Card Tray: passo 22, imagem 1 %32
    • Insert a SIM card opening tool into the small hole on the left side of the phone and remove the SIM card tray.
  23. LG G6 Charge Port Replacement: passo 23, imagem 1 %32 LG G6 Charge Port Replacement: passo 23, imagem 2 %32 LG G6 Charge Port Replacement: passo 23, imagem 3 %32
    • Lift the motherboard out of the phone.
    • Be careful not to snag any of the connectors on the board.
  24. LG G6 Charge Port Replacement, Charge Port: passo 24, imagem 1 %32 LG G6 Charge Port Replacement, Charge Port: passo 24, imagem 2 %32 LG G6 Charge Port Replacement, Charge Port: passo 24, imagem 3 %32
    • Use the flat end of a spudger to remove the adhesive securing the USB-C charge port to the frame.
Conclusão
13 outras pessoas executaram este guia.
Kevin Stuckey
Membro desde: 01/11/15
1.217 Reputação
Autoria de 2 guias
Equipe
Anchor Technology Solutions Membro de Anchor Technology Solutions
Business
1 Membro
Autoria de 3 guias
6Comentários do guia
Excellent AAAAAAAAA ++++
Jose G Ramirez - Responder Compartilhar
Awesome tutorial, I skipped the from step 11 to 15. No need to remove the button assembly. Just skipped that and reused the back glass panel with no problems. Thank you!
Ben Fischer - Responder Compartilhar
Thanks for your input. It has been a while!
Were you able to replace the port or the port assembly?
FrancisF - Compartilhar
I can’t get the back off. I’ve tried so hard but it wont come off. I pulled so &&^&^$^ hard i cracked the back but couldnt get the &&^&^$^ back off wtf
Pengo The Penguino - Responder Compartilhar
Hi , I have replaced the port but usb comm still not working. QC3 not working because it also works with working usb comm. I have tried many original cords and chargers.
malikzee111 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 41
Últimos 30 dias: 113
Ao todo: 19,559
