Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
LG G5 Rear Camera Replacement
O que você precisa
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: passo 1, imagem 1 %32 LG G5 Rear Camera Replacement, Front Panel Assembly: passo 1, imagem 2 %32
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Rear Camera Replacement: passo 2, imagem 1 %32 LG G5 Rear Camera Replacement: passo 2, imagem 2 %32 LG G5 Rear Camera Replacement: passo 2, imagem 3 %32
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Rear Camera Replacement: passo 3, imagem 1 %32 LG G5 Rear Camera Replacement: passo 3, imagem 2 %32
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Rear Camera Replacement: passo 4, imagem 1 %32
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Rear Camera Replacement: passo 5, imagem 1 %32 LG G5 Rear Camera Replacement: passo 5, imagem 2 %32
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Rear Camera Replacement: passo 6, imagem 1 %32 LG G5 Rear Camera Replacement: passo 6, imagem 2 %32
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Rear Camera Replacement, Rear Camera: passo 7, imagem 1 %32 LG G5 Rear Camera Replacement, Rear Camera: passo 7, imagem 2 %32 LG G5 Rear Camera Replacement, Rear Camera: passo 7, imagem 3 %32
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
  8. LG G5 Rear Camera Replacement: passo 8, imagem 1 %32 LG G5 Rear Camera Replacement: passo 8, imagem 2 %32
    • After detaching the ribbon, carefully remove the camera using tweezers
Conclusão
34 outras pessoas executaram este guia.
Parker Reynolds
Membro desde: 10/03/16
932 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-2, Forte Fall 2016 Membro de Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
Membros da 4
Autoria de 15 guias
6 comentários
This worked great and took me about 10 minutes!
Mark - Responder
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - Responder
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - Responder
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - Responder
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 17,177
