Ir para o conteúdo principal
LG G5 Front Panel Assembly
O que você precisa
  1. LG G5 Front Panel Assembly, Front Panel Assembly: passo 1, imagem 1 %32 LG G5 Front Panel Assembly, Front Panel Assembly: passo 1, imagem 2 %32
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Front Panel Assembly: passo 2, imagem 1 %32 LG G5 Front Panel Assembly: passo 2, imagem 2 %32 LG G5 Front Panel Assembly: passo 2, imagem 3 %32
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Front Panel Assembly: passo 3, imagem 1 %32 LG G5 Front Panel Assembly: passo 3, imagem 2 %32
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Front Panel Assembly: passo 4, imagem 1 %32
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Front Panel Assembly: passo 5, imagem 1 %32 LG G5 Front Panel Assembly: passo 5, imagem 2 %32
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Front Panel Assembly: passo 6, imagem 1 %32 LG G5 Front Panel Assembly: passo 6, imagem 2 %32
    • Peel the screen away from the body. The two parts should be completely separated.
Conclusão
Now you can access all the inner components of the phone!
32 outras pessoas executaram este guia.
Joshua Zalmanowitz
Membro desde: 09/27/16
1.817 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-2, Forte Fall 2016 Membro de Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Membros
Autoria de 15 guias
4Comentários do guia
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - Responder
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - Responder
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - Responder
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 87
Ao todo: 10,262
