Ir para o conteúdo principal
LG G5 Charging Port Replacement
O que você precisa
  1. LG G5 Charging Port Replacement, Battery: passo 1, imagem 1 %32 LG G5 Charging Port Replacement, Battery: passo 1, imagem 2 %32 LG G5 Charging Port Replacement, Battery: passo 1, imagem 3 %32
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Charging Port Replacement: passo 2, imagem 1 %32 LG G5 Charging Port Replacement: passo 2, imagem 2 %32
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    You should be able to pull it out by pulling down and away at the same time.
    This video has a better explanation of how its done.
    Germanetti Rosas - Responder
    Para temover a bateria, é só puxar???
    eliezerhenriquesilva - Responder
  3. LG G5 Charging Port Replacement, Charging Port: passo 3, imagem 1 %32 LG G5 Charging Port Replacement, Charging Port: passo 3, imagem 2 %32
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Charging Port Replacement: passo 4, imagem 1 %32 LG G5 Charging Port Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tool into the bottom seam
    • Pry the plastic from the base only a slight amount.
  5. LG G5 Charging Port Replacement: passo 5, imagem 1 %32 LG G5 Charging Port Replacement: passo 5, imagem 2 %32
    • Remove the one 5.5mm Phillips #000 screw.
  6. LG G5 Charging Port Replacement: passo 6, imagem 1 %32 LG G5 Charging Port Replacement: passo 6, imagem 2 %32 LG G5 Charging Port Replacement: passo 6, imagem 3 %32
    • Insert the plastic opening tool into the seam between the two plastic layers.
    • Pry the plastic from the body.
  7. LG G5 Charging Port Replacement: passo 7, imagem 1 %32 LG G5 Charging Port Replacement: passo 7, imagem 2 %32
    • Insert the plastic opening tool into the seam under the metal charging port.
    • Pry the metal charging port from the body.
Conclusão
23 outras pessoas executaram este guia.
Joshua Zalmanowitz
Membro desde: 09/27/16
1.811 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-2, Forte Fall 2016 Membro de Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
Membros da 4
Autoria de 15 guias
13 comentários
I would love steps to show not only pulling out the usb port, but also putting the new one in and re-assembly. Also maybe tips about things to avoid doing -- easy slip ups people make when doing it. Why replace just the usb port instead of the whole board assembly or instead of the entire bottom module? Thanks! Great pics
jessicacollins267 - Responder
Anyone know how to bypass the "insert a supported module" error that comes up after changing the charging port?
Rene - Responder
Do you solve the problem? Can you help me, please?
Budai Daniel -
I need to do this repair on my phone, but Rene's comment worries me. Does this error message come up often? Can it be fixed?
Brad - Responder
Hello. I have the same problem like Rene . I changed the usb port and when I try to power on my smartphone it shows me the picture that said “insert a supported module” like what Rene said earlier. Please, I need help.
Budai Daniel - Responder
Your question is pretty old, but here's the late answer.
It seems only original modules were accepted.
Buy an original LG module and it shouldn't work.
wundama -
Did you get rid of error ?
Would be nice to know…cmon people ! That was 1.5 yrs ago !
Eric Wilhelm -
I just finished putting a new USB charging port in mine. It worked fine no worries. Buy parts from a actual cell phone place and you shouldn’t have any problems. No more ding please put charger in to usb 500 times a day. Thank You for this guide.
Jeff Yaciuk - Responder
Not all parts are compatible with all phone models out there. And not all dealers are correctly advertising their parts as “working with” when they don’t work with that model. Even though charging ports are ranging from $15-$20 and impossible to know compatibility until you buy and attempt replacement.
Anyone have consistent experience with replacement parts?
Thomas J - Responder
I also had Rene’s problem. I purchased from iFixit.
Jennifer Knack - Responder
Edit: I purchased the charging port from iFixit and my phone from AT&T.
Jennifer Knack -
One more edit (and this might be the problem): I have the H820, not H850.
Jennifer Knack -
I ordered the correct new charging port , I installed the battery to the module, turned on phone and
screen read install correct module. ? It is the correct one, wtf, Do I need a new battery or why is it not working
Rick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 23,810
