Ir para o conteúdo principal
LG G5 Battery Replacement
O que você precisa
  1. LG G5 Battery Replacement, Battery: passo 1, imagem 1 %32 LG G5 Battery Replacement, Battery: passo 1, imagem 2 %32 LG G5 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: passo 2, imagem 1 %32 LG G5 Battery Replacement: passo 2, imagem 2 %32
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    You should be able to pull it out by pulling down and away at the same time.
    This video has a better explanation of how its done.
    Germanetti Rosas - Responder
    Para temover a bateria, é só puxar???
    eliezerhenriquesilva - Responder
Conclusão
21 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.854 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.198 guias
4 comentários
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Responder
Was machen wenn Akku Snap In ab ist?
Ra Ku - Responder
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Responder
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 91
Duração total: 15,586
