Introdução
If the battery in your LG G4 dies very quickly, or does not charge at all, this guide will show you how to replace the battery. It is an easy replacement, and requires only a plastic opening tool to accomplish.
O que você precisa
First, make sure the phone is powered off. Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
13 outras pessoas executaram este guia.
