Introdução
Use this guide to replace the headphone jack in your LG G3 Vigor.
O que você precisa
Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
Remove the front camera.
Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
