Ir para o conteúdo principal
LG G3 Vigor Front Facing Camera Replacement
O que você precisa
  1. LG G3 Vigor Front Facing Camera Replacement, Rear Case: passo 1, imagem 1 %32
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Front Facing Camera Replacement: passo 2, imagem 1 %32
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Front Facing Camera Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Front Facing Camera Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Front Facing Camera Replacement: passo 5, imagem 1 %32 LG G3 Vigor Front Facing Camera Replacement: passo 5, imagem 2 %32 LG G3 Vigor Front Facing Camera Replacement: passo 5, imagem 3 %32
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: passo 6, imagem 1 %32 LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: passo 6, imagem 2 %32
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard.
    • Remove the front camera.
Conclusão
Equipe
USF Tampa, Team 12-5, Eyestone Spring 2016 Membro de USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 294
