Ir para o conteúdo principal
LG G3 Vigor Earpiece Speaker Replacement
O que você precisa
  1. LG G3 Vigor Earpiece Speaker Replacement, Rear Case: passo 1, imagem 1 %32
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Earpiece Speaker Replacement: passo 2, imagem 1 %32
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Earpiece Speaker Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Earpiece Speaker Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Earpiece Speaker Replacement: passo 5, imagem 1 %32 LG G3 Vigor Earpiece Speaker Replacement: passo 5, imagem 2 %32 LG G3 Vigor Earpiece Speaker Replacement: passo 5, imagem 3 %32
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Earpiece Speaker Replacement, Rear Facing Camera: passo 6, imagem 1 %32
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: passo 7, imagem 1 %32 LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: passo 7, imagem 2 %32
    • Remove the front camera.
  8. LG G3 Vigor Earpiece Speaker Replacement, Motherboard: passo 8, imagem 1 %32
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Earpiece Speaker Replacement: passo 9, imagem 1 %32 LG G3 Vigor Earpiece Speaker Replacement: passo 9, imagem 2 %32
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Earpiece Speaker Replacement, Earpiece Speaker: passo 10, imagem 1 %32
    • Remove the earpiece speaker with the metal spudger by prying it out.
Conclusão
Uma outra pessoa concluiu este guia.
Geoff Wacker
Membro desde: 09/30/13
91.140 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 288
