Ir para o conteúdo principal
LG G3 Screen flicker and fades
O que você precisa
  1. LG G3 Screen flicker and fades, Place The Folden Paper Here!: passo 1, imagem 1 %32
    • Place The Paper Here On this Connector!
    Pergunte ao FixBot
    Comentar
  2. LG G3 Screen flicker and fades, Thermal Paste: passo 2, imagem 1 %32
    • A small dot will do the job better than overfilling !
    Pergunte ao FixBot
    Comentar
Conclusão
It is not to Hard to perform this Fix.
Just don't touch anything else and be careful while taking the plastic cover off....
Everything is going to be fine.
61 outras pessoas executaram este guia.
albanjakupi
Membro desde: 02/15/17
1.837 Reputação
Autoria de 1 guia
57Comentários do guia
Shume mire !! A ke Informacion si po ndrohet " Displayglass", jo krejt Display, po vetem ajo Pjesa e pare.
Tfala Bekim Jakupi
Bekim Jakupi - Responder Compartilhar
I am not sure who this is going to but I wanted to know about the repair of the flickering and fading screen of the LG G3. Is that procedure a long term fix and what causes the symptoms. Also is the little piece of paper any type of fire hazard. The repair worked and it blows my mind. Thank you so much. I brought my phone to a repair shop and they were unable to fix it, Thank you again. If you wish to respond to me. My name is rich and my E-MAIL address is raidernation61@sbcglobal.net.
raidernation61 - Responder Compartilhar
do you have a gmail ? i want ask about this lg g3 problem . ty
wawan D - Responder Compartilhar
I don't know why, but this works! Thank You!
dlinsc - Responder Compartilhar
Absolutely worked. Thanks for this. The flex cable just need to be push hard to the socket.
Ronald Tariga - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 63
Ao todo: 64,651
