Ir para o conteúdo principal
LG G3 Power & Volume Button Cable Replacement
O que você precisa
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: passo 1, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement, Back Cover: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Power & Volume Button Cable Replacement: passo 2, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 2, imagem 2 %32
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Power & Volume Button Cable Replacement, Battery: passo 3, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement, Battery: passo 3, imagem 2 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Power & Volume Button Cable Replacement: passo 4, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 4, imagem 2 %32
    • Lift the battery out of its recess and remove it.
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: passo 5, imagem 1 %32
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Power & Volume Button Cable Replacement: passo 6, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 6, imagem 2 %32
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Power & Volume Button Cable Replacement: passo 7, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 7, imagem 2 %32 LG G3 Power & Volume Button Cable Replacement: passo 7, imagem 3 %32
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: passo 8, imagem 1 %32
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Power & Volume Button Cable Replacement: passo 9, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 9, imagem 2 %32 LG G3 Power & Volume Button Cable Replacement: passo 9, imagem 3 %32
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Power & Volume Button Cable Replacement: passo 10, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 10, imagem 2 %32 LG G3 Power & Volume Button Cable Replacement: passo 10, imagem 3 %32
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: passo 11, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: passo 11, imagem 2 %32
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
  12. LG G3 Power & Volume Button Cable Replacement: passo 12, imagem 1 %32 LG G3 Power & Volume Button Cable Replacement: passo 12, imagem 2 %32 LG G3 Power & Volume Button Cable Replacement: passo 12, imagem 3 %32
    • Using the spudger, release power & volume button flex from adhesive carefully.
  13. LG G3 Power & Volume Button Cable Replacement: passo 13, imagem 1 %32
    • Finally, remove the flex.
Conclusão
9 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
Um comentário
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Duração total: 22,012
