Ir para o conteúdo principal
LG G3 Battery Replacement
O que você precisa
  1. LG G3 Battery Replacement, Back Cover: passo 1, imagem 1 %32 LG G3 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: passo 2, imagem 1 %32 LG G3 Battery Replacement: passo 2, imagem 2 %32
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: passo 3, imagem 1 %32 LG G3 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: passo 4, imagem 1 %32 LG G3 Battery Replacement: passo 4, imagem 2 %32
    • Lift the battery out of its recess and remove it.
Conclusão
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.160 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
Um comentário
Thank you very much!
ItayDigital - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 17,570
