Ir para o conteúdo principal
LG G3 Back Cover Replacement
O que você precisa
  1. LG G3 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 LG G3 Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Back Cover Replacement: passo 2, imagem 1 %32 LG G3 Back Cover Replacement: passo 2, imagem 2 %32
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
Conclusão
4 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
201.012 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 16.558 guias
Um comentário
Really. Was this necessary
James Beam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 4,427
