Ir para o conteúdo principal
LG G3 - How to fix GPS not working
O que você precisa
  1. LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: passo 1, imagem 1 %32 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: passo 1, imagem 2 %32 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: passo 1, imagem 3 %32
    • Shutdown your phone.
    • Remove the back cover of the phone
    • Unscrew all the screws identified in red in the picture.
    • Remove the plastic covers using your fingernails or a plastic tool.
  2. LG G3 - How to fix GPS not working: passo 2, imagem 1 %32
    • Carefully peel off the 3 metal stickers (connectors) identified in white on the photo with a flat screwdriver.
    • Please note these stickers are fragile and can tear.
    • Cut pieces of a sheet of cardboard or a sheet thick enough to the size of the stickers.
    • Glue a piece of cardboard or thick paper under each sticker to create extra thickness.
    • Replace the stickers in their original location (they will no longer stick to the shell, but that's okay).
    • Reassemble the phone by repeating the previous steps, taking care to tighten the screws properly when reassembling
Conclusão
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
draxx
Membro desde: 02/08/19
175 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 2,239
