Ir para o conteúdo principal
LG G2 Vibrator Motor Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 10 são provenientes de um guia marcado como em andamento.
    LG G2 Vibrator Motor Replacement, Motherboard: passo 1, imagem 1 %32
    • Using the plastic opening tool, or the thin side of the spudger to separate the back cover from the phone. Start at the bottom corner of the phone. Be gentle because it may cause cosmetic and internal damage if not done with care.
  2. LG G2 Vibrator Motor Replacement: passo 2, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 2, imagem 2 %32
    • With the back cover removed you will get a view like this.
    • Use the Phillips 00 screw driver to remove all visible screws. Try to organize the screws so there is no confusion when reassembling the phone.
    • 6 silver cross head phillips #1 4mm screws circled in red.
    • 5 gold cross head phillips #1 4mm screws circled in yellow.
    • 1 black cross head phillips #2 2mm screws circled in blue.
  3. LG G2 Vibrator Motor Replacement: passo 3, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 3, imagem 2 %32
    • After all visible screws have been removed use the spudger to pop off the top plastic cover.
  4. LG G2 Vibrator Motor Replacement: passo 4, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 4, imagem 2 %32
    • Do the same for the bottom plastic cover.
  5. LG G2 Vibrator Motor Replacement: passo 5, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 5, imagem 2 %32 LG G2 Vibrator Motor Replacement: passo 5, imagem 3 %32
    • The motherboard should be full visible now.
    • Start loosening all the connectors to the motherboard with the pointy side of the spudger. Look at picture to make sure all connectors have been disconnected.
  6. LG G2 Vibrator Motor Replacement: passo 6, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 6, imagem 2 %32
    • After all connector are loosened up the motherboard should be free, but before removing it lets disconnect it a little further.
    • The flex cables running on the left and right side of the battery are connected to a smaller board connected which on their turn is connected with small amounts of adhesive materials to the motherboard. Use the spudger to carefully separate the smaller board of the motherboard.
  7. LG G2 Vibrator Motor Replacement: passo 7, imagem 1 %32
    • Make sure you pay attention when removing the left flex cable because it is also connected to the side. Simply just peal this part away also. It may be a little more difficult than the upper connections, but just peel away. It may bend a little but be careful not to break.
  8. LG G2 Vibrator Motor Replacement: passo 8, imagem 1 %32
    • It may seem as if the flex cable are free to remove, but not yet. The two flex cable are both together at the bottom, and connected to a small control board. Therefore we need to remove the control board completely.
  9. LG G2 Vibrator Motor Replacement: passo 9, imagem 1 %32
    • Disconnect the 2 connectors. The LCD connector (red color coded) and the Digitizer (yellow color coded). Together with these 2, remove the 2 antenna connections (green color coded) also.
  10. LG G2 Vibrator Motor Replacement: passo 10, imagem 1 %32 LG G2 Vibrator Motor Replacement: passo 10, imagem 2 %32
    • The motherboard is also held down with some adhesive but carefully can be pried up. Make use of Spudger.
    • When motherboard is removed you will get a view like this.
  11. LG G2 Vibrator Motor Replacement, Vibrator Motor: passo 11, imagem 1 %32 LG G2 Vibrator Motor Replacement, Vibrator Motor: passo 11, imagem 2 %32
    • This is a picture of the location of the vibrator motor.
    • It may require some prying due to the cohesive material used to hold it down so be gentle when removing.
    • Make use of spudger.
Conclusão
4 outras pessoas executaram este guia.
Jair
Membro desde: 10/09/14
1.518 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-1, Blackwell Fall 2014 Membro de USF Tampa, Team 2-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 1,562
