Introdução
The vibe motor requires most of the phone to be dissected. Make sure to keep track of all screws and parts that are removed. Pay close attention to the guide for parts that are glued and not screwed or clipped into the phone.
O que você precisa
Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
The vibe motor is attached to the phone case with adhesive. Make sure to use your plastic prying tool to softly remove the motor from the case.
Uma outra pessoa concluiu este guia.
