Ir para o conteúdo principal
LG G Watch R Battery Replacement Replacement
O que você precisa
  1. LG G Watch R Battery Replacement Replacement, Back Case: passo 1, imagem 1 %32 LG G Watch R Battery Replacement Replacement, Back Case: passo 1, imagem 2 %32
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Replacement Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Replacement Replacement: passo 3, imagem 1 %32
    • Remove the back case.
  4. LG G Watch R Battery Replacement Replacement, Motherboard: passo 4, imagem 1 %32 LG G Watch R Battery Replacement Replacement, Motherboard: passo 4, imagem 2 %32
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Replacement Replacement: passo 5, imagem 1 %32 LG G Watch R Battery Replacement Replacement: passo 5, imagem 2 %32
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Replacement Replacement: passo 6, imagem 1 %32
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Replacement Replacement, Battery Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
Conclusão
70 outras pessoas executaram este guia.
Westley Courchene
Membro desde: 01/13/15
3.389 Reputação
Autoria de 14 guias
Equipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
Membros da 5
Autoria de 14 guias
13 comentários
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - Responder
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet -
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 66
Duração total: 30,099
