Ir para o conteúdo principal
LG G Watch Motherboard Replacement
O que você precisa
  1. LG G Watch Motherboard Replacement, Wristband: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Motherboard Replacement: passo 2, imagem 1 %32 LG G Watch Motherboard Replacement: passo 2, imagem 2 %32
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Motherboard Replacement, Rear Case: passo 3, imagem 1 %32
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Motherboard Replacement: passo 4, imagem 1 %32 LG G Watch Motherboard Replacement: passo 4, imagem 2 %32
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Motherboard Replacement, Gasket: passo 5, imagem 1 %32
    Comprar
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 LG G Watch Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Motherboard Replacement: passo 7, imagem 1 %32 LG G Watch Motherboard Replacement: passo 7, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Meles Anneaud
Membro desde: 09/23/14
140 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-5, Blackwell Fall 2014 Membro de USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
Membros da 5
Autoria de 9 guias
Um comentário
is it possible to replace the battery which is in the board?
Vassago U7 (VassagoU7) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,061
