Introdução
This guide will show you how to replace the motherboard in your LG G Watch.
O que você precisa
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Use the spudger to gently lift up and disconnect the display connector.
Now use the spudger to disconnect the digitizer connector.
4 outras pessoas executaram este guia.
Um comentário
is it possible to replace the battery which is in the board?
