Ir para o conteúdo principal
LG G Watch Battery Replacement
O que você precisa
  1. LG G Watch Battery Replacement, Wristband: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Battery Replacement: passo 2, imagem 1 %32 LG G Watch Battery Replacement: passo 2, imagem 2 %32
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Battery Replacement, Rear Case: passo 3, imagem 1 %32
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Battery Replacement: passo 4, imagem 1 %32 LG G Watch Battery Replacement: passo 4, imagem 2 %32
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Battery Replacement, Battery: passo 5, imagem 1 %32 LG G Watch Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the two black Phillips #000 2.5x3mm screws that are located on the right side of the metal clip.
  6. LG G Watch Battery Replacement: passo 6, imagem 1 %32
    Comprar
    • Use a pair of tweezers to gently lift the metal retaining clip up and out of the way.
  7. LG G Watch Battery Replacement: passo 7, imagem 1 %32 LG G Watch Battery Replacement: passo 7, imagem 2 %32
    • Use a spudger to gently pry the battery up from the rear case.
    • The battery is attached with a small amount of adhesive, so some force may be required.
Conclusão
7 outras pessoas executaram este guia.
Deja Miller
Membro desde: 10/14/14
462 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-5, Blackwell Fall 2014 Membro de USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
Membros da 5
Autoria de 9 guias
4 comentários
Hello where can i buy the battery and the tools to perform this function. Also I love my lg watch and I get 3 days before needing a recharge but, i do not play with it and do not add all the fancy watch faces either. just look at text messages and see who is calling. I think its the best out there only draw back is the cradle charger. please email me. buckeybandit69@gmail.com.
thank you..
Brian Adams - Responder
where can i but the battery
bikerdennis321 - Responder
I know how to change but where can i buy the battery for this watch//
I had mine on eBay. Search for LG W100KT 400mAh Battery-BL-S1
It works perfectly till now.
MrPatate - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 54
Duração total: 8,248
