Introdução
This guide will teach you how to replace the screen on your LG G Vista. The screen of the device won't physically detach, and you will be left with the entire display assembly instead.
O que você precisa
Using a Phillips #000 screwdriver, remove all eleven 3.0 mm screws from around the perimeter of the phone.
To reassemble your device, follow these steps in reverse order.
