Ir para o conteúdo principal
LG G Vista Screen Replacement
O que você precisa
  1. LG G Vista Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the device is powered off.
    Pergunte ao FixBot
    Comentar
  2. LG G Vista Screen Replacement: passo 2, imagem 1 %32
    • Remove the back cover by gently prying open the case of the device from the charging port.
    Pergunte ao FixBot
    Comentar
  3. LG G Vista Screen Replacement: passo 3, imagem 1 %32
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
    Pergunte ao FixBot
    Comentar
  4. LG G Vista Screen Replacement, Screen: passo 4, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove all eleven 3.0 mm screws from around the perimeter of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG G Vista Screen Replacement: passo 5, imagem 1 %32
    • Use a plastic spudger or opening tool and run it along the seam of the upper cover.
    • Carefully remove the cover from the device.
    Pergunte ao FixBot
    Comentar
  6. LG G Vista Screen Replacement: passo 6, imagem 1 %32
    • Use the same method to pry off the hard shell covering at the bottom.
    Pergunte ao FixBot
    Comentar
  7. LG G Vista Screen Replacement: passo 7, imagem 1 %32
    • Remove the two 1 mm Phillips #000 screws.
    Pergunte ao FixBot
    Comentar
  8. LG G Vista Screen Replacement: passo 8, imagem 1 %32 LG G Vista Screen Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Gently using tweezers, disconnect the connector that is on the bottom right.
    Pergunte ao FixBot
    Comentar
  9. LG G Vista Screen Replacement: passo 9, imagem 1 %32 LG G Vista Screen Replacement: passo 9, imagem 2 %32
    • Gently unplug the antenna wires on the bottom left and right sides of the device.
    Pergunte ao FixBot
    Comentar
  10. LG G Vista Screen Replacement: passo 10, imagem 1 %32
    • With your plastic opening tool, gently lift up the bottom edge of the exposed charging port, sliding along the edge until it lifts out.
    Pergunte ao FixBot
    Comentar
  11. LG G Vista Screen Replacement: passo 11, imagem 1 %32
    • Using tweezers, unplug the four connectors.
    Pergunte ao FixBot
    Comentar
  12. LG G Vista Screen Replacement: passo 12, imagem 1 %32 LG G Vista Screen Replacement: passo 12, imagem 2 %32
    • Remove the antenna wires on both sides of the device.
    Pergunte ao FixBot
    Comentar
  13. LG G Vista Screen Replacement: passo 13, imagem 1 %32 LG G Vista Screen Replacement: passo 13, imagem 2 %32
    • Carefully lift out the back camera from the device.
    • Lift out the headphone jack in the upper right side of the device.
    Pergunte ao FixBot
    Comentar
  14. LG G Vista Screen Replacement: passo 14, imagem 1 %32
    • Remove the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
  15. LG G Vista Screen Replacement: passo 15, imagem 1 %32
    • Remove the vibration motor from the device.
    • You will be left with the entire display assembly of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these steps in reverse order.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,040
