Ir para o conteúdo principal
LG G Vista Motherboard Replacement
O que você precisa
  1. LG G Vista Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the device is powered off.
  2. LG G Vista Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Motherboard Replacement: passo 3, imagem 1 %32
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  5. LG G Vista Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the hard shell covering the motherboard.
  6. LG G Vista Motherboard Replacement: passo 6, imagem 1 %32
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  7. LG G Vista Motherboard Replacement: passo 7, imagem 1 %32 LG G Vista Motherboard Replacement: passo 7, imagem 2 %32
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
  8. LG G Vista Motherboard Replacement: passo 8, imagem 1 %32
    • Lift up and remove the motherboard from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 460
