Introdução
If you are experiencing hardware issues or water damage to the overall phone. You can replace the motherboard and fix your LG G Stylo without buying a replacement.
O que você precisa
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
I need help urgently please
Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
Fully remove the motherboard by prying upward with the plastic opening tool.
These pictures sb. numbered
The pictures shown need to be#”d and also what part # do we order???
6 outras pessoas executaram este guia.
6 comentários
Do you know where the wifi chip is?
Do you guys know where i can get a new motherboard for an lg stylo?
A family member of mine snapped my phone in half with my baby's pictures on it.
I asked my boyfriend to back up the pictures… well, he figured after thanksgiving when I will have more happy photos…
So, any hope of getting them?
The motherboard is partly missing.
The SD card was full so most were on the phone.
Achte carte mere LG stylus2 vs 2016
