Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your phone dies quickly even when it was full charged or doesn't even charge at all, this guide will walk you through how to replace the battery of your phone. Only tool you need for this guide is plastic opening tool.
O que você precisa
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
6 outras pessoas executaram este guia.
Um comentário
Thank you for your help. This has been making us crazy, your time is much appreciated.
