Ir para o conteúdo principal
LG G Stylo Battery Replacement
O que você precisa
  1. LG G Stylo Battery Replacement, Battery: passo 1, imagem 1 %32 LG G Stylo Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: passo 2, imagem 1 %32 LG G Stylo Battery Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
    George japhet - Responder
    I need help urgently please
Conclusão
6 outras pessoas executaram este guia.
Douglas Schmidt
Membro desde: 02/09/16
422 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 11-7, Cheng Spring 2016 Membro de USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
Membros da 4
Autoria de 14 guias
Um comentário
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 60
Duração total: 12,838
