Ir para o conteúdo principal
LG G Stylo Battery Replacement
O que você precisa
  1. LG G Stylo Battery Replacement, Battery: passo 1, imagem 1 %32 LG G Stylo Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: passo 2, imagem 1 %32 LG G Stylo Battery Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
Conclusão
6 outras pessoas executaram este guia.
Douglas Schmidt
Membro desde: 02/09/16
422 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 11-7, Cheng Spring 2016 Membro de USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Membros
Autoria de 14 guias
1Comentário do guia
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 77
Ao todo: 13,764
