Introdução
This replacement guide will show you how to safely and properly remove the screen on your LG G Pad X 8.3.
O que você precisa
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
Insert the plastic opening tool on one of the corners of the device.
Slowly go around the edge of the tablet with the plastic opening tool and pry upward.
Use multiple plastic opening tools underneath areas that have been pried open. This will prevent the screen from sticking back to the adhesive and it will make removal easier.
3 outras pessoas executaram este guia.
2 comentários
I have a question. Mine was dropped and has a crack across the screen - I’d keep using it with a glass screen protector on it if I could, it’s not that bad. HOWEVER, when it dropped and broke the screen, the digitizer stopped working.
Does anybody know if the digitizer is integrated with the back light or if it’s closer to the screen? I don’t see any ribbon cables being removed in this guide so I’m assuming that it’s deeper than just the screen.
Any help would be wonderful I’m trying to decide if I want to fix this thing or just recycle it, I love the pen and the size, but it’s fairly outdated now and not the fastest thing in the world. I have another tablet and a nice phone, but was going to give this to my brother.
Nice guide, I’ve used iFixIt guides a few times in the past to fix friend’s devices… my phone/tablet/laptop repair tool, screw driver, and screw kit collection is pretty massive and impressive now LOL.
Thanks!
