Ir para o conteúdo principal
LG G Pad X 8.3 Rear-facing camera Replacement
O que você precisa
  1. LG G Pad X 8.3 Rear-facing camera Replacement, Battery: passo 1, imagem 1 %32
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Rear-facing camera Replacement: passo 2, imagem 1 %32
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Rear-facing camera Replacement: passo 3, imagem 1 %32
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Rear-facing camera Replacement: passo 4, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 4, imagem 2 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 4, imagem 3 %32
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Rear-facing camera Replacement: passo 5, imagem 1 %32
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Rear-facing camera Replacement: passo 6, imagem 1 %32
    • Lift the battery with your fingers and remove it from the device.
  7. LG G Pad X 8.3 Rear-facing camera Replacement, Speaker: passo 7, imagem 1 %32
    • With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
    • Use the magnetic mat to keep track of the tiny screw(s).
  8. LG G Pad X 8.3 Rear-facing camera Replacement: passo 8, imagem 1 %32
    • Lift and remove the speaker with your finger.
  9. LG G Pad X 8.3 Rear-facing camera Replacement, Motherboard: passo 9, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement, Motherboard: passo 9, imagem 2 %32
    • With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
  10. LG G Pad X 8.3 Rear-facing camera Replacement: passo 10, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard.
    • Only lift up the end of the ribbon connector that is attached to the motherboard. The end at the base of the tablet should stay attached.
  11. LG G Pad X 8.3 Rear-facing camera Replacement: passo 11, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 11, imagem 2 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 11, imagem 3 %32
    • Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool.
    • Avoid bending the tips of the ribbon connectors to prevent damage.
  12. LG G Pad X 8.3 Rear-facing camera Replacement: passo 12, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 12, imagem 2 %32
    • With your fingers, lift up the motherboard from the upper right corner.
    • Carefully remove the fragile motherboard from the device.
  13. LG G Pad X 8.3 Rear-facing camera Replacement, Rear-facing camera: passo 13, imagem 1 %32
    • Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
  14. LG G Pad X 8.3 Rear-facing camera Replacement: passo 14, imagem 1 %32 LG G Pad X 8.3 Rear-facing camera Replacement: passo 14, imagem 2 %32
    • After prying ribbon connector, the rear-facing camera should be ready for removal.
    • Gently lift the rear-facing camera with your fingers and remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 101
