Ir para o conteúdo principal
LG G Pad F 7.0 Speaker Replacement
O que você precisa
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: passo 1, imagem 1 %32 LG G Pad F 7.0 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: passo 2, imagem 1 %32 LG G Pad F 7.0 Speaker Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: passo 3, imagem 1 %32 LG G Pad F 7.0 Speaker Replacement: passo 3, imagem 2 %32 LG G Pad F 7.0 Speaker Replacement: passo 3, imagem 3 %32
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
Conclusão
Jose Hurtado
Membro desde: 01/25/17
329 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-5, Banghart Winter 2017 Membro de Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 183
