Ir para o conteúdo principal
LG G Pad F 7.0 Battery Replacement
O que você precisa
  1. LG G Pad F 7.0 Battery Replacement, Battery: passo 1, imagem 1 %32 LG G Pad F 7.0 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: passo 2, imagem 1 %32 LG G Pad F 7.0 Battery Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: passo 3, imagem 1 %32
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: passo 4, imagem 1 %32 LG G Pad F 7.0 Battery Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
Conclusão
Matt Kloos
Membro desde: 01/25/17
249 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-5, Banghart Winter 2017 Membro de Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
Membros da 3
Autoria de 10 guias
Um comentário
Pictures are all in focus and easy to follow
Jonah Basl - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 685
