Ir para o conteúdo principal
LG G Pad 8.3 4G Battery Replacement
O que você precisa
  1. LG G Pad 8.3 4G Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Battery Replacement: passo 2, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 2, imagem 2 %32 LG G Pad 8.3 4G Battery Replacement: passo 2, imagem 3 %32
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Battery Replacement, Speakers: passo 3, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement, Speakers: passo 3, imagem 2 %32
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. LG G Pad 8.3 4G Battery Replacement: passo 4, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 4, imagem 2 %32 LG G Pad 8.3 4G Battery Replacement: passo 4, imagem 3 %32
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. LG G Pad 8.3 4G Battery Replacement: passo 5, imagem 1 %32
    • Pull the cable back and out of the way of the speaker.
  6. LG G Pad 8.3 4G Battery Replacement: passo 6, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 6, imagem 2 %32
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
  7. LG G Pad 8.3 4G Battery Replacement, Vibrator: passo 7, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement, Vibrator: passo 7, imagem 2 %32
    • Remove the two screws on the white panel on the bottom right side.
  8. LG G Pad 8.3 4G Battery Replacement: passo 8, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 8, imagem 2 %32
    • Remove the white panel.
  9. LG G Pad 8.3 4G Battery Replacement: passo 9, imagem 1 %32
    • Remove the vibrator from the underside of the white panel.
  10. LG G Pad 8.3 4G Battery Replacement, Battery: passo 10, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement, Battery: passo 10, imagem 2 %32
    • Remove the 3 silver 1.5 mm screws that remain.
  11. LG G Pad 8.3 4G Battery Replacement: passo 11, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 11, imagem 2 %32
    • Remove the 2 black 1.5 mm screws.
  12. LG G Pad 8.3 4G Battery Replacement: passo 12, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 12, imagem 2 %32
    • Insert metal spudger under the side of the gold strip and pull.
  13. LG G Pad 8.3 4G Battery Replacement: passo 13, imagem 1 %32 LG G Pad 8.3 4G Battery Replacement: passo 13, imagem 2 %32
    • Place spudger under the top of the gold bar and gently pry up.
  14. LG G Pad 8.3 4G Battery Replacement: passo 14, imagem 1 %32
    • Pull on top of the silver block until gold bar lifts.
  15. LG G Pad 8.3 4G Battery Replacement: passo 15, imagem 1 %32
    • Place spudger under the battery and run it around the edge to loosen it.
  16. LG G Pad 8.3 4G Battery Replacement: passo 16, imagem 1 %32
    • Pull the battery out.
Conclusão
Um comentário
I have followed your guide (LG G Pad 8.3 4G Battery Replacement) but what see when I pry off the screen is not what is on your pic of step 2.
It appears that I have to pry off the back panel to actually see the battery, the speakers and the gold cable.
How can I pry off the back panel?
Thanks,
Ed
Ed Miller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 525
