Ir para o conteúdo principal
LG G Pad 7.0 LTE Camera Replacement
O que você precisa
  1. LG G Pad 7.0 LTE Camera Replacement, Removing the Back Cover: passo 1, imagem 1 %32
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Camera Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Camera Replacement, Camera: passo 3, imagem 1 %32
    • Disconnect camera ribbon cable by prying up on it with a plastic pry tool.
  4. LG G Pad 7.0 LTE Camera Replacement: passo 4, imagem 1 %32
    Comprar
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device (red marker).
  5. LG G Pad 7.0 LTE Camera Replacement: passo 5, imagem 1 %32
    • Install the new camera into device by gently placing it in its corresponding place until it pops in.
Conclusão
Uma outra pessoa concluiu este guia.
Fadi Bitar
Membro desde: 09/26/16
880 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 14-6, Eyestone Fall 2016 Membro de USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 335
