Introdução
In cases where the battery is not charging or the device isn’t powering on, this guide will help you replace the battery to fix these issues.
O que você precisa
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
Disconnect the battery connector by prying it upwards (blue marker).
Remove the ribbon cable by prying it upwards (red marker).
4 comentários
No trick, follow instruction in reverse substituting the new battery and you’ll be golden.
