Ir para o conteúdo principal
LG G Pad 7.0 Battery Replacement
O que você precisa
  1. LG G Pad 7.0 Battery Replacement, Front Panel: passo 1, imagem 1 %32 LG G Pad 7.0 Battery Replacement, Front Panel: passo 1, imagem 2 %32
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: passo 2, imagem 1 %32 LG G Pad 7.0 Battery Replacement, Battery Connector: passo 2, imagem 2 %32 LG G Pad 7.0 Battery Replacement, Battery Connector: passo 2, imagem 3 %32
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
Conclusão
19 outras pessoas executaram este guia.
echow2001
Membro desde: 09/05/15
2.158 Reputação
Autoria de 4 guias
1Comentário do guia
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 17,841
