Ir para o conteúdo principal
LG Front Load Washing Machine Inlet Valve Filters Replacement
O que você precisa
  1. LG Front Load Washing Machine Inlet Valve Filters Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Filters Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: passo 2, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: passo 2, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: passo 2, imagem 3 %32
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
37.485 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.839 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 800
