Ir para o conteúdo principal
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: passo 1, imagem 1 %32 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: passo 1, imagem 2 %32
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, imagem 1 %32 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, imagem 2 %32 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, imagem 3 %32
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, imagem 1 %32 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, imagem 2 %32 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, imagem 3 %32
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
30.542 Reputação
Autoria de 213 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.745 guias
Um comentário
I need to replace the clip door it fell off when we moved.
Maria Medina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 128
Duração total: 1,232
