Ir para o conteúdo principal
LG Front Load Washing Machine Detergent Dispenser Replacement
O que você precisa
  1. LG Front Load Washing Machine Detergent Dispenser Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Detergent Dispenser Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent drawer: passo 5, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent drawer: passo 5, imagem 2 %32
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Detergent Dispenser Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 6, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 6, imagem 3 %32
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: passo 7, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: passo 7, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: passo 7, imagem 3 %32
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: passo 8, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: passo 8, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: passo 8, imagem 3 %32
    • Unclip any connections the control panel cable has to the chassis or other components.
  9. LG Front Load Washing Machine Detergent Dispenser Replacement, Detergent dispenser hose information: passo 9, imagem 1 %32
    • To prevent confusion, label each detergent hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  10. LG Front Load Washing Machine Detergent Dispenser Replacement: passo 10, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 10, imagem 2 %32
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  11. LG Front Load Washing Machine Detergent Dispenser Replacement: passo 11, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 11, imagem 2 %32
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  12. LG Front Load Washing Machine Detergent Dispenser Replacement: passo 12, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement: passo 12, imagem 2 %32
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  13. LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: passo 13, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: passo 13, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: passo 13, imagem 3 %32
    • Loosen any fasteners securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  14. LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the detergent dispenser: passo 14, imagem 1 %32
    • Remove the screw(s) securing the detergent dispenser.
  15. LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: passo 15, imagem 1 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: passo 15, imagem 2 %32 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: passo 15, imagem 3 %32
    • Slide the detergent dispenser out of its slot in the chassis to unclip it.
    • Completely separate the dispenser from the chassis.
  16. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent dispenser: passo 16, imagem 1 %32
    • Remove the detergent dispenser.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.516 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.752 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 103
Ao todo: 2,123
