Ir para o conteúdo principal
LG Front Load Washing Machine Dampers Replacement
O que você precisa
  1. LG Front Load Washing Machine Dampers Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Dampers Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Dampers Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: passo 5, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: passo 5, imagem 2 %32
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Dampers Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement: passo 6, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement: passo 6, imagem 3 %32
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: passo 7, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: passo 7, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: passo 7, imagem 3 %32
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: passo 8, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: passo 8, imagem 2 %32
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Dampers Replacement, Unfasten the detergent dispenser: passo 9, imagem 1 %32
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: passo 10, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: passo 10, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: passo 10, imagem 3 %32
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Dampers Replacement, Remove the control panel: passo 11, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: passo 11, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: passo 11, imagem 3 %32
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Dampers Replacement, Open the door: passo 12, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Open the door: passo 12, imagem 2 %32
    • Open the front door completely.
  13. LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: passo 13, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: passo 13, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: passo 13, imagem 3 %32
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Dampers Replacement: passo 14, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement: passo 14, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement: passo 14, imagem 3 %32
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: passo 15, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: passo 15, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: passo 15, imagem 3 %32
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Dampers Replacement: passo 16, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement: passo 16, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement: passo 16, imagem 3 %32
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: passo 17, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: passo 17, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: passo 17, imagem 3 %32
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Dampers Replacement, Drain the machine: passo 18, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Drain the machine: passo 18, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Drain the machine: passo 18, imagem 3 %32
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Dampers Replacement, Unfasten the filter trim: passo 19, imagem 1 %32
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: passo 20, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: passo 20, imagem 2 %32
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Dampers Replacement, Unfasten the lower front panel: passo 21, imagem 1 %32
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Dampers Replacement, Unfasten the door latch: passo 22, imagem 1 %32
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Dampers Replacement, Remove the door latch: passo 23, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: passo 23, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: passo 23, imagem 3 %32
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: passo 24, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: passo 24, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: passo 24, imagem 3 %32
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Dampers Replacement, Remove the front panel: passo 25, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: passo 25, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: passo 25, imagem 3 %32
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Dampers Replacement: passo 26, imagem 1 %32
    • Remove the front panel.
  27. LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: passo 27, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: passo 27, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: passo 27, imagem 3 %32
    • Remove the screw(s) securing the rear panel.
  28. LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: passo 28, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: passo 28, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: passo 28, imagem 3 %32
    • Unclip the rear panel from the chassis.
  29. LG Front Load Washing Machine Dampers Replacement: passo 29, imagem 1 %32
    • Remove the rear panel.
  30. LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: passo 30, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: passo 30, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: passo 30, imagem 3 %32
    • Depending on your repair, you might need to access the dampers from the rear, the front, or both ends of the device. Choose whichever method works best for you.
    • Use a flathead screwdriver to press down on the tab securing the plastic pin.
    • You can also used an appropriately-sized box wrench to compress the pins.
    • Use a hammer to tap the pin out of its hole, still making sure the tab is compressed.
    • Repeat this procedure until the pin is loose enough to be removed with your hands.
  31. LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: passo 31, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: passo 31, imagem 2 %32
    • Remove the plastic pin.
    • Repeat these two steps for the second pin on the damper.
    • If your replacement dampers don't come with new pins, apply silicone grease to the old pins during reassembly.
  32. LG Front Load Washing Machine Dampers Replacement, Remove the damper: passo 32, imagem 1 %32 LG Front Load Washing Machine Dampers Replacement, Remove the damper: passo 32, imagem 2 %32 LG Front Load Washing Machine Dampers Replacement, Remove the damper: passo 32, imagem 3 %32
    • Slide the damper out of its slot in the chassis to disconnect it.
    • Remove the damper.
    • If you're having difficulty removing the damper, compress it to shorten its length.
    • Repeat the last two steps for each damper you want to replace.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.528 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.765 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 39
Últimos 30 dias: 170
Ao todo: 2,572
