Introdução
If you've dropped your LG Fortune 2 and noticed screen cracks or greenish imperfections (backlight bleed), it may be time to replace your screen. The process is very straightforward, requires two tools, and will help salvage your phone. Don't overpay for a professional or buy a new phone. Instead say "I fix it" and use this guide.
O que você precisa
Use the slit on the bottom left side of the phone to open the back cover using your hand.
Use the groove at the bottom of the phone to remove the battery.
