Ir para o conteúdo principal
LG Flare Microphone Replacement
O que você precisa
  1. LG Flare Microphone Replacement, Microphone: passo 1, imagem 1 %32 LG Flare Microphone Replacement, Microphone: passo 1, imagem 2 %32
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: passo 2, imagem 1 %32
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: passo 3, imagem 1 %32
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: passo 4, imagem 1 %32
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: passo 5, imagem 1 %32
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: passo 6, imagem 1 %32
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: passo 7, imagem 1 %32
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: passo 8, imagem 1 %32 LG Flare Microphone Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: passo 9, imagem 1 %32
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: passo 10, imagem 1 %32
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
Conclusão
Kelsey Hanna
Membro desde: 09/29/15
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-3, Garvin Fall 2015 Membro de Ohio State, Team 1-3, Garvin Fall 2015
OSU-GARVIN-F15S1G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 198
