Ir para o conteúdo principal
LG Escape (p870) Loudspeaker Assembly Replacement
O que você precisa
  1. LG Escape (p870) Loudspeaker Assembly Replacement, Battery: passo 1, imagem 1 %32 LG Escape (p870) Loudspeaker Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Loudspeaker Assembly Replacement: passo 2, imagem 1 %32 LG Escape (p870) Loudspeaker Assembly Replacement: passo 2, imagem 2 %32
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 3, imagem 1 %32
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Loudspeaker Assembly Replacement: passo 4, imagem 1 %32 LG Escape (p870) Loudspeaker Assembly Replacement: passo 4, imagem 2 %32
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
Conclusão
Uma outra pessoa concluiu este guia.
Brad
Membro desde: 08/12/12
1.908 Reputação
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 315
