Ir para o conteúdo principal
LG Escape (p870) LCD Screen Replacement
O que você precisa
  1. LG Escape (p870) LCD Screen Replacement, Battery: passo 1, imagem 1 %32 LG Escape (p870) LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) LCD Screen Replacement: passo 2, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 2, imagem 2 %32
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) LCD Screen Replacement, Loudspeaker Assembly: passo 3, imagem 1 %32
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) LCD Screen Replacement: passo 4, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 4, imagem 2 %32
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) LCD Screen Replacement, Touch screen/digitizer: passo 5, imagem 1 %32
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) LCD Screen Replacement: passo 6, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 6, imagem 2 %32 LG Escape (p870) LCD Screen Replacement: passo 6, imagem 3 %32
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) LCD Screen Replacement: passo 7, imagem 1 %32
    • Wifi and cell service antennas
    • LCD connector
    • Back camera connector
    • Front camera connector
    • Touch screen/ digitizer connector
    • Charger port connector
    • Headphone jack connector
  8. LG Escape (p870) LCD Screen Replacement: passo 8, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 8, imagem 2 %32 LG Escape (p870) LCD Screen Replacement: passo 8, imagem 3 %32
    • With a spudger or safe open pry tool, carefully detach the LCD flex connector
    • Release the two antennae from their connectors
    • Release the back camera's flex from its connector
  9. LG Escape (p870) LCD Screen Replacement: passo 9, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 9, imagem 2 %32
    • Release the charging port flex from its connector
    • Release the front camera's flex from its connector
    • Release the touch screen/digitizer's flex cable from its connector
  10. LG Escape (p870) LCD Screen Replacement: passo 10, imagem 1 %32
    • Release the headphone jack's flex cable from its connector
  11. LG Escape (p870) LCD Screen Replacement: passo 11, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 11, imagem 2 %32
    • With a pair of tweezers, VERY carefully pull the volume button flex out of the rear housing
    • Repeat the process with the power button flex cable
    • The power button and volume button flex cables will tear very easily, so be cautious
  12. LG Escape (p870) LCD Screen Replacement: passo 12, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 12, imagem 2 %32
    • Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
    • Set the motherboard aside
  13. LG Escape (p870) LCD Screen Replacement: passo 13, imagem 1 %32 LG Escape (p870) LCD Screen Replacement: passo 13, imagem 2 %32
    • Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
    • Gently pry on the bezel to release the clips adhering the screen to the mid-frame
    • Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
    • Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
    • After carefully threading the digitizer and outer housing/bezel from the middle bracket you'll notice the digitizer is held on by a band of very strong adhesive - this will be destroyed when you take off the old digitizer. When you replace your digitizer you can use double-sided tape or epoxy to hold the new digitizer on the bezel.
  14. LG Escape (p870) LCD Screen Replacement, LCD Screen: passo 14, imagem 1 %32
    • Peel off the adhesive portion of the LCD ribbon cable from the back of the phone
  15. LG Escape (p870) LCD Screen Replacement: passo 15, imagem 1 %32
    • Lift the LCD from its bottom edge and work the ribbon cable carefully through the hole
    • Set the LCD aside
Conclusão
Uma outra pessoa concluiu este guia.
Brad
Membro desde: 08/12/12
1.908 Reputação
Autoria de 10 guias
Um comentário
Just replaced my broken screen by following these directions. Back together now and all works well except the camera. I'm just getting a fuzzy gray or green screen. Took apart a second time to make sure the camera connectors were installed properly and they seem to be. Put back together again but camera is still screwed up.
Any suggestions?
Chuck - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,719
